These wheels gonna help over stock??
Rears
http://www.summitracing.com/parts/SUM-571-5862PS/
Fronts
http://www.summitracing.com/parts/SUM-571-5461PS/
found a pic of these on a T/A and really liked them and for the price that will make them look that much better to me but question is will these help at all ET wise I've heard they are a lil bit heavier then the Welds etc. but i mean have to be quite a bit lighter then stock???
and will them fronts be the right BS and such???
Thanks for input and advice in advance
Ryan,
Fronts
Ryan,
That's an ignorant statement.....The summit versions of draglites etc. are just about as good as welds. And when you're on a budget, there is no reason these won't be a fine choice. I would love me a set of weld draglites but I don't feel like spending that much $ on them especially since I drive my car often and will probably only use them for the track.
I don't recall what spacer is needed but IIRC the LT1 brakes will accept these wheels without grinding but LS1 cars need to be ground down a bit.
Try a set of Summit® Warrior R/T wheels on your ride. These one-piece cast aluminum wheels are polished for good looks and feature classic 5-spoke styling. Warrior R/T wheels are available in a wide range of popular bolt patterns and backspacing to suit your needs.
These Weld Prostar polished wheels are like no other wheels on the street or strip. They're precision-crafted from cold-forged aluminum for superior strength and are up to 40% lighter than comparable race wheels. The wheels are guaranteed tubeless and include an aluminum push-through center cap.
I was talking more on the lines of a drag setup. I wouldn't DD my skinnies and would most likely run slicks on the rears, thus the words "drag setup". If I did DD with that I would spend the money on draglites.
Just get some nittos on the rear and get some skinnys and swap them on at the track. M/T's are better but wear very fast. I have the nittos for my shooters and M/T'S on drag lights for the track. But like u seen i cut a 1.7 60' with a full weight and stock motor on nittos
