LS2 Swap into 98SS: Fuel pump question
Old 05-31-2011, 12:21 AM
UberTruck's Avatar
Default LS2 Swap into 98SS: Fuel pump question
Simple question:
Will my stock pump (whats is it, a 170?) support my H/C/I LS2 with stock LS2 injectors? I'll be using the SS fuel setup entirely.
Should I just go ahead and get the 255? I do plan on spraying this car with 150, so I'm sure i'll need the additional volume/pressure...
Guess I just need someone to hold my hand and confirm my suspicion? lol.
Old 05-31-2011, 04:03 AM
itsslow98's Avatar
your gonna wanna do the 255 and when you spray the 150 shot your gonna have to add another pump somewhere. a single in tank 255 isnt gonna support a h/c/i 150 shot car. an in tank 255 with a hotwire harness is usualyl maxed out around 530-550. you may want to look into the new aeromotive 340 in tank if you can find one.
as far as injectors ls2s are rated at 28lbs if i recall and youll be maxing those out h/c/i. Id pick up some 36lbers or 42s.
