2008 LS3 Sensor Pinouts
I am using an aftermarket ECU on an LS3 and need some help with sensor pin outs.
I need:
Cam
Crank
MAP
Oil Press
DBW TB
DBW Pedal
Thanks.
I need:
Cam
Crank
MAP
Oil Press
DBW TB
DBW Pedal
Thanks.
I can help with the MAP:
LS3:
Pin 1 - 5 volts - gray
Pin 2 - Ground (low reference) - orange/black
Pin 3 - Signal to PCM - light green
now if someone just happened to have the LS1 version pinout, I'd be very happy (need to rewire my setup without burning my car down )
LS3:
Thank you very much.
I have found the LS1 pinouts through various sources, including, IIRC, on this forum when I did a search. I didn't really log where it was because I am not focused on the earlier stuff, but you should be able to find it relatively easily.
Anybody else have any of the other ones?
The pinouts are available at www.myraceshop.com under the reference section.
http://myraceshop.com/Reference/GTM-...Pin%20Outs.pdf
