Thunder Racing's TRuTorq L5 LS3 Cam Results
We are currently finishing the tune on a 2010 Camaro SS and it looks like we are knocking on the 500 RWHP door with a cam only setup. The mods are as follows:
Thunder Racing TRuTorq Level 5 cam 227/239 .614"/.621" 115LSA
Comp 26925 Spring Kit shimmed to TR specs
Dynatech 1 7/8" LT with Off-road pipes
QTP Dual Cutouts
Stock LS3 Longblock
Stock LS3 Intake Manifold
TR 6060 trans w/stock drivetrain and wheels
Best pull so far 498 RWHP SAE Corrected.
Dyno graph to follow...
Shane
QTP Dual Cutouts
Stock LS3 Longblock
Shane
The cam drives well even with the stock gears. I have a video and dyno graph which I will post shortly. This is the 5th time we've installed this particular cam in an LS3 build. The lowest performing car made 486. All testing was done with 93 octane pump gas on stock LS3's. We are going to install this cam in our shop test car soon which has a ported intake and a little bowl and chamber work. I'll post results as I get them...
Thanks,
Shane
Thanks,
Shane
I had high expectations from this cam long time ago and I searched A LOT about it but I couldn't find any results other than the dyno sheet on Thunder's website
I'm so glad to see those outstanding results for this great cam.
How do you think this cam will do on an LS7?
I also have a 239/251 115 option specifically for LS7's with those with more aggressive tastes...
Thanks,
Shane
QTP Dual Cutouts
Stock LS3 Longblock
Shane
QTP Dual Cutouts
Stock LS3 Longblock
Shane
Thanks a ton!
Great job shane. Congrates my brotha.. I am looking forward to getting my car back together soon. When it's finished you still gonna come to the track with me to setup the suspension? I am gonna need to get the Wolf rear any sway bar put in first though.. I'll call you when I get everything back in the car man.. Again great results on the car..
Thanks,
Shane
Thanks Shane, I really like the results from this cam, will be nice to hear a sound clip on a 115 in your spare time. I will keep this in mind when the time comes to mod the G8, great job.
what about the
"TR TRuTorq" Level 3 - 223/236 .612/.610 115 LSA
with 102mm Intake and TB 3.7 geare what do U think it going to be on ls1 cause i'm planing to get one
What about this cam with a 416ci shortblock with my G8 GT heads with valve job and my ported intake and TB and of course a bigger than my stock MAF ??? I've really been thinking about stroking the 4 Door Fury ...... thanks
