Tire Pressure Monitoring System
Old 05-31-2011, 09:09 PM
BLKIL08SS's Avatar
Default Tire Pressure Monitoring System
I think mine is messed up. It will tell me to check R Frnt tire. But when I push the button on the dash to see what that says where the pressure is at, it reads 7....then up to...38....down to...25....goes off....back on...So just wondering if anyonhe else has had this issue. Will be calling the dealership since it is still under warranty.
Old 06-01-2011, 01:05 AM
SigmaX6's Avatar
I had a similiar issue but whenever the valve got wet aka rained outside id instantly get a low pressure followed by your issue. Changing the sensor fixed it.
Old 06-28-2011, 09:09 PM
BLKIL08SS's Avatar
Well It finally told me to service TPMS so I took it in.....just in case anyone was wondering being that so many people chime in on post on this site....
Old 06-29-2011, 05:12 PM
Panther427's Avatar
its great they keep adding little extra electronic stuff to break on the car
Old 06-30-2011, 10:05 PM
Kazmaniac's Avatar
Welcome to the forums ...
Unfortunately we all had problems like this 5 years ago, and everything was discussed back then.
Now it seems like there are more reposts than news here.
Old 06-30-2011, 10:19 PM
Donk's SS's Avatar
If you have a Discount Tire near you, take it to them. They will "scan" each of the sensors to see if there is a bad one or just reset the system for you. It only takes a couple of minutes and it should/will be free.
Old 07-01-2011, 03:07 AM
heavyft's Avatar
I sprayed Wd40 on my valve stem then capped them. I haven't had a false low pressure alert in 2 years.
