Small Block & Big Block Chevy Specific - what distrubitor for bbc
View Full Version : what distrubitor for bbc
botlfed
06-01-2011, 02:16 PM
Looking for a distributor for my 468 street strip nova even when on the street ill beat the piss out of it should I go hei or regular dist with box.
quick77
06-01-2011, 02:55 PM
MAD makes a 'ready to run' billet dist. It has their hei module in it. No msd box needed. These dist. have the ability to set up the rate of advance as well as being able to change bushings that change the amt. of advance in the dist. You will need plug wires that have hei style ends along with a coil, if you can,use a blaster3 coil,it has a built in tower to cut out shorting from the positive/neg. posts to the coil wire.
cambirdracing
06-01-2011, 04:19 PM
Fixed it for ya
MSD makes a 'ready to run' billet dist. It has their hei module in it. No msd box needed. These dist. have the ability to set up the rate of advance as well as being able to change bushings that change the amt. of advance in the dist. You will need plug wires that have hei style ends along with a coil, if you can,use a blaster3 coil,it has a built in tower to cut out shorting from the positive/neg. posts to the coil wire.
I don't think a HEI will fit without hammering the firewall in. Go with the billet MSD as stated above.
botlfed
06-01-2011, 06:44 PM
So the msd with the built in hei
quick77
06-01-2011, 07:24 PM
I am using one in my 71 camaro . Like cambird stated ....the large Diameter of the gm hei doesn't fit well in a,nova, my son has a 467" sbc in his 69 nova,uses a dart tall deck sm block,with the extra height,a std. dia. cap is all that fits!!
quick77
06-01-2011, 07:28 PM
LOL ....just noticed that!! Spell check on my phone gets me in trouble now n then.... yeah MSD :)
