Parking Brake Sensor?
i was wondering if anyone had a picture or knew where to buy a parking brake sensor? the BRAKE light is on at all times and the car is failing inspection because of it. the car has no abs (sjm kit), but the light did not come on until a few months after the abs was deleted, so i doubt it is this. the master cylinder is also full of fluid, so im fairly certain its the sensor. is there any way to jump it?
do i need to remove the lower console too or just the upper? when i look all i see is what appears to be an airbag sensor, the wires for the PRND display and the console light, and an unused pigtail, presumably for a lockout switch for a 6 speed i guess.
