Anyone running an 85mm MAF?
Old 06-01-2011, 06:04 PM
speed_demon24's Avatar
Default Anyone running an 85mm MAF?
I know LSx guys are picking up power with them. Are they plug and play in our cars too? I think i remember reading somewhere that they max out pretty early on our cars but it's been awhile since I did any research into them. Trying decide what to do before I order a regular lid or a lid for an 85mm MAF.
Old 06-01-2011, 06:33 PM
BADHAWK51's Avatar
Your probably going to get mixed feed back on this, but I would keep the stock maf I have seen very good results with it. Larry Speed Inc 10.67 on motor Butch (Bolo) 11.00's on motor. I run an 85mm but have been thinking of switching back to see what the real gain or loss is.
Old 06-01-2011, 07:06 PM
Just because someone ran xx.xx with a stock maf doesn't mean it is a restriction at that level, and if an 85mm delco/delphi maf isn't any harder to tune than a 75mm MAF....
Old 06-01-2011, 07:18 PM
BADHAWK51's Avatar
I guess what I'm trying to say is why waste your money on a maf when the stock one is perfectly fine for atleast na applications.
Old 06-01-2011, 09:02 PM
I'm trying to figure out if that's the case. Some LSx guys with less power than me are reporting gainsr with bigger MAF's, and LT1's come with the same MAF from the factory.
Old 06-01-2011, 09:32 PM
96capricemgr's Avatar
The LT1 pcm only "understands" them to something like 360gps because the MAF is meant to match a pcm that can read a higher frequency range. Beyond that point the tuning will basically need to be treated speed density. Talk to your tuner.
PM me if you like too I played with this when it first came out.
Old 06-01-2011, 09:46 PM
IronOutlaw's Avatar
So I guess the EFI 24x could benefit from it though.
Old 06-03-2011, 03:17 PM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
I ran a Z06 85mm on my car for years without any issues. The EFI 24x would benefit from this more than the LTx due to the PCM restrictions.
The values out there to put the Z06 MAF into a LT1 PCM I actually came up with years and years ago. (I have the posts on CZ28.com to prove it, and the spreadsheet that I did it with! lol).
The reason I did it wasn't a performance standpoint. The reason for me was a cost basis. My stocker **** the bed, and the Z06 one at the time was 1/3 the price; plus the $15 for the adapter cable; it was a no-brainer once I figured out the PCM values.
Old 06-03-2011, 06:46 PM
DisturbedTA's Avatar
i have one!i like it,it feels like it has better responce
Old 06-03-2011, 09:13 PM
flyinZ's Avatar
Id talk to Ed Wright. Im pretty sure, he did back-to-back tests with the factory MAF, vs. the 85mm MAF.
Old 06-03-2011, 09:55 PM
FASTFATBOY's Avatar
Ed Wright said its worth 4-5 rwhp, ones on mine.
Old 06-03-2011, 10:37 PM
Tensec94z's Avatar
Have one on mine too.
Old 06-06-2011, 06:56 PM
Talked to my tuner. He shut down the 85mm MAF idea pretty quick so I'll be sticking with the stock one.
Old 06-06-2011, 06:59 PM
96TransAmboosted's Avatar
Good idea
Old 06-06-2011, 07:09 PM
mysticbowtie's Avatar
I installed one on my new build, and Ed made me take it off and go speed density.... You can't argue with Mr. Wright's experience! Now it and the wiring harness are collecting dust in a drawer. Thanks for reminding me to sell it!
Old 06-06-2011, 08:27 PM
97Z28SS's Avatar
Well this is good news I'm going to put one on my new engine with the EFI 24x ignition.
Old 02-13-2012, 09:08 PM
James Montigny's Avatar
How did it work out for you?
I recently installed a stock LT1 MAF in my 93 with a 24x to get it to idle properly until I get the car tuned.
I'm trying to decide if I want to run a MAF (stock or otherwise) once I have a proper tune or if SD is the way to go.
Quick Reply: Anyone running an 85mm MAF?
