lt1 5.7 sleeper caprice 13 second run?
Old 06-01-2011, 11:43 PM
Joey Forbes's Avatar
Default lt1 5.7 sleeper caprice 13 second run?
My car is a 1996 Caprice 9C1 with 114,000 miles and my goal is to exceed over a 13 second run on a 1/4 mile with a stock bottom end and keeping the costs at a low budget.
I've only done a few common cheap mods to the car, cold air intake, throttle body bypass, deleted mufflers and resonators on stock exhuast.
Here's a list of what I plan on doing to the car so far, I still haven't decided on a few things like transmission and need guidance and suggestions.
exhaust: long tube headers / fake cats / 2.5 exhaust / spintech sportsman xl mufflers / pre axle dumps
ignition: gm performance ac delco optispark distributor / msd 8.5 wires / ac delco plugs
differential: ford 8" rear end with 3.73 gears with a eaton posi unit and disc brakes.
pcm tuning: 93 octane conversion, delete rear oxygen sensors, air pump delete.
Old 06-02-2011, 01:26 AM
food nd cars's Avatar
if you have the cash for all that then I would suggest a more aggressive cam than stock (with all supporting valve train), plus a stall. I would think that this alone would put you in the high 13s at least.. but then again I don't know much about B-bodies
Old 06-02-2011, 02:59 AM
gregrob's Avatar
Why in the hell would you swap out the 8.5 for a ford 8.8
IIRC the pinion stem diameter of the 8.5 is bigger than an 8.8 anyway. Same size as a 12 bolt
The 8.5 can be built to handle a lot before it needs upgrading... A buddy goes 8.20s with one....
Old 06-02-2011, 03:32 AM
etc.'s Avatar
A perfectly running car, 2800+ stall, headers, 373+ gears, 2 1/2 exhaust and sticky tires, tune. You should be very low 14s if not high 13s.
And keep the 10 bolt.
Old 06-02-2011, 10:17 PM
Transporter9033's Avatar
Most definately keep that 8.5! I know a guy that has an amazingly fast (9.xx @ over 150 MPH) Impala SS and he is still using the 10 bolt housing that came with the car.
Quick Reply: lt1 5.7 sleeper caprice 13 second run?
