Small Block & Big Block Chevy Specific - how good are the bbc dimple rods with 7/16 bolts
botlfed
06-02-2011, 05:31 AM
Im thinking about changing from a cast crank to steel and forged pistons I have dimple rods now I've heard of people saying these were 4340 from gm anyone no actually how good they are
cambirdracing
06-02-2011, 06:06 AM
With new ARP bolts, they should support up to 700 hp. Oh yea, and polish the beams.
botlfed
06-02-2011, 07:06 AM
I no a guy that has a pulling truck and he spins it at 8000 he says he has them and he says he has like 900 horsepower.
P.Wallnuts
06-02-2011, 10:23 PM
The LS6s use these rods and I have read in HRM that those bottom ends are good for 900 hp. I couldn't tell you an exact issue but if they are publishing 900 then you might get away with a little more.
mm8ls1
06-03-2011, 11:49 AM
With those rods u have to be careful and checkout the pin end. You'll notice that the metal doesn't haven't equal thickness surrounding the pin hole. You'll see this all too often.
mm8ls1
06-03-2011, 11:51 AM
I have a set of used 6.135 Eagles and a set of Lunati 6.135 pro mod rods if u need.
