Header Gasket Question
I bought a set of Pacesetter headers from a member and was wondering if I can use stock gaskets with these headers? Do I have to get the gaskets from Pacesetter or will any header gasket for an LS1 work? Thanks for the help.
Matt
Matt
Originally Posted by Trans_AmGuy
Your stockers will work fine.... I'm still using the same ones from my Mac headers and now Jet Hots.
Thanks again
Matt
There wont be any difference but I'm still using the stock metal ones. The others have a tendancy to tear if you're not careful when you try to start some of the header bolts. BTW you can reuse your stock header bolts as well if they are still in good shape.
Originally Posted by WILWAXU
IMO, use the stock ones or GM replacements. They kick azz!
Matt
1 Post
Originally Posted by nbmls1ta
Ok, that makes me feel alot better. I was afraid I was going to have to order special gaskets. I am happy now. Thanks guys!!!
Matt
Matt
I'm about to install my Pacesetters also. When you say use the stock gaskets, does it mean that I can reuse the ones that are on the car with the stock manifolds right now. Or do I need to go to GM and order the same part number.
Thanks
Thanks
Thanks
IMO, I'd get some new metal GM gaskets... I had a friend of mine from these boards recommend getting some new ones, and when we pulled my exhaust manifolds and saw the gaskets, I'm glad I did. Sure they were re-useable, but they weren't in the best of shape. And my car only has 18600 miles on it.
