AcIdBuRn02ZTS
06-02-2011, 05:54 PM
Hey alls...
If you read my other post about the P0758 issue I was having... You know what Ive already been fighting on this stupid truck...
So... After replacing...
Both Shift Solenoids
3-2 Downshift Solenoid
ECU
Ignition Switch
Testing continuity between all the trans related pins on the ecu all the way to the plugs on the solenoids and testing the new solenoids...
I dont have 1st gear...
When in drive, go to take off, truck is in 3rd although my scanner is showing that the trans should be in 1st and both solenoids are on. Manually shift to 1st and the truck is in 2nd....
It shifts fine from 2nd through 4th and has no trouble codes now... So the solenoids are working otherwise I would lose more then one gear...
So... I'm planning on dropping the pan yet again come saturday morning and I want to know what in the world would cause me to just lose 1st gear? Is it in the valve body or what? What should I be looking for??
Please help
Thanks
-Chris
ECU
Ignition Switch
Please help
Thanks
-Chris
