Power Window Problem
Old 06-03-2011, 03:29 PM
Bird.is.Word's Avatar
Default Power Window Problem
I just put a new window motor in my 99 Trans Am. The motor itself works fine. The problem is that when I roll the window all the way down, it won't go back up. The motor doesn't even make any noise when I hit the switch. The weird thing is that the window will go back up if it hasn't been rolled all the way down. Even if it's only a c#nt hair away from being all the way down, it will go back up. Anyone had this problem before?
Old 06-03-2011, 10:40 PM
sjsingle1's Avatar
driver? pass ?
Old 06-04-2011, 08:14 AM
Save the manuals!
wssix99's Avatar
Your motor is bad. Very common.
Either:
- Someone returned a bad motor to the parts store and they turned around and sold it to you.
- You purchased a dud reman motor. (Your issue is with the thermal cutoff switch which some remans reuse - not a good thing.)
If you go with a Dorman design motor, you shouldn't have any issues. Its 100% new and an upgraded design.
Old 06-05-2011, 01:39 PM
Cool. Thanks for the info man.
