power steering
power steering
quick ?, the oil on my power steering leaks from the top where the cap is. i checked the cap and it seems to be ok, and is thight. ive checked the oil level and its almost all the way to the top, its at that level when my car is hot or cold. can anyone tell me the cause of this and how to fix it.
Save the manuals!
When the car is cold, the level should be at the "cold" mark on the dipstick. If its above that, you need to take fluid out. If it still overflows after that, you need to a complete flush of the fluid. It tends to act up with age. (Better cooling helps, but from my experience the age of the fluid is a bigger issue.)
