G spot on power window motor
Hey, so for a long time now i have been having issues with my power window on the drivers side. I have tried replacing it a bunch of times. It works, then stops, then it would only work when i pulled a couple wires and just kind of jiggled them. I am sure it is a wiring or harness problem, but is there any easy fix for this? I have taken the inner door panel off, but its pretty hard to get in there and see the wires. Anyone else have any experience with this?
Save the manuals!
Are you putting it on with the speaker out of the door? I had to use a pair of extra long nose pliers to hold the wire and then get up in there with my other hand to get it on straight. You can confirm with an inspection mirror.
