M12 ? in a gto
Old 06-04-2011, 04:02 AM
04gto5.7's Avatar
Default M12 ? in a gto
ok i know the gto comes with the M12 tranny but will a normal f-body T56 be the same. i know the gear ratios and other things are different but will it bolt in using the stock crossmember and driveshaft and does the shifter mount the same thanks
Old 06-04-2011, 09:52 AM
thesource's Avatar
You can bolt an F body trans right in place. All you need to do is swap the shift selector arm out in the tailhousing with the one from your current unit.
Old 06-04-2011, 04:24 PM
04gto5.7's Avatar
sorry to sound dumb but are u talking about the piece that your shifter sits on like what controls the linkage in the gates a link to see what exactly your talking about would greatly be appreciated
Old 06-04-2011, 04:30 PM
studderin's Avatar
The cup the shifter arm (ball) gose in.
Old 06-04-2011, 04:48 PM
04gto5.7's Avatar
Oh ok thats easy enough
Quick Reply: M12 ? in a gto
