Rear, off-set LCAs only available with rod ends?
I'm in need of lower control arms that are off set for use with wider wheels/tires, but can only find ones with rod ends. Due to some of the rod-end complaints I've read on this site, I'd like to avoid them. Do off set LCAs with polyurethane ends exist??
You'd have to create your own bushing end with a threaded shaft offset from the center of the end. JasonWW might be a good resource for that.
There's nothing special about an offset LCA that uses rod ends. What makes them 'offset' is the spacers are wider on one side. If you already have rod ended LCA's you could just buy spacers for them.
