gbabyfoo321
06-04-2011, 01:37 PM
anybody have any info on how they made theirs? dimensions or other helpful hints?
i figure id go buy some sheet aluminum and cut it up. did you guys bolt it from the inside or from under the hood?
also, if i wanted to keep heat (i pretty much destroyed all plastic parts), i need to make a box for the blower fan? and then fun the heat/coolant lines (the ones coming from the water pump) into the aluminum heater (core) thing?
newb here. thanks in advance
