Power Seat Wiring
Old 06-05-2011, 09:25 AM
MetallicaMatt's Avatar
Default Power Seat Wiring
I've had my interior apart for awhile, and I've got the carpet back in and put the seats in and now I think I am missing something. Under the seat I have a white plug coming from the main harness that runs along the door frame. Then, there are the air tubes for the lumbar supports and a black electrical connection. Both of these run from seat to seat.
Under each seat is a black electrical connection and the air tube connection.
How do I connect the WHITE connector? The seats aren't getting power, so I'm guessing the white plug is the power source.
Is there a 2 into 1 connector I've lost? If so, should there be one for each side? Both seats have the exact setup.
I swore I saw a randome 2 into 1 pigtail laying around, and I cannot find it anywhere. Does anybody have the GM Part number for this? (if my thinking is correct)
Here is a picture of the plugs, underneath the seat:
Old 06-06-2011, 05:45 PM
anybody?
Old 06-06-2011, 08:32 PM
ls1okie's Avatar
Your missing a male white connector that plugs into the white one you have pictured. Look under the carpet. The black one plugs into the driver side seat motor.
Old 06-06-2011, 08:37 PM
where is the white male connector coming from? I moved some of the wires around.
I hope I don't have to pull this apart!
Old 06-06-2011, 08:45 PM
ls1okie's Avatar
It comes from under the carpet. Im assuming it goes to the passenger side lumbar to supply power. Gotta love putting things back together after being apart for a while. LOL
Old 06-06-2011, 08:50 PM
the passenger side has the exact same setup.
So I'm wondering. Do the white and black connectors plug into a 2 into 1, and that plugs into the black plug on the seat?
Old 06-06-2011, 08:58 PM
oh and each white connector, is coming from the main harness that runs along the door
Old 06-06-2011, 09:13 PM
ls1okie's Avatar
The black connector plugs ino the driver seat motor. Should be a male and female( both white connectors) plugged togethor under driver seat, Im betting your other white connector is still under the carpet.
Old 06-06-2011, 09:14 PM
Crap!
Where would the male connector be coming from?
Old 06-06-2011, 09:21 PM
ls1okie's Avatar
Same harnes that is coming from under carpet now. Prob still tucked under carpet
Old 06-06-2011, 09:28 PM
why would 2 white connectors plug together from the same harness?
The black plug and the wire tubes, run from seat to seat, over the trans tunnel. The seats do not get power with the black connectors plugged in.
Old 06-06-2011, 09:35 PM
ls1okie's Avatar
Im just telling you how mine is. I have had seats out multiple times, Thats how they are hooked up. Black connector to driver seat power motor white male and female connectors with orange and black wires plugged together.
Old 06-06-2011, 09:38 PM
do you remember where the white male connector is located? I felt around and couldn't feel anything...but not really sure where to look.
Old 06-06-2011, 09:42 PM
ls1okie's Avatar
Never had carpet out. it comes through with the others.
Old 06-07-2011, 11:26 AM
I just can't think of where the white male is coming from.
And how do my power seats, get power? The black plug just goes to the passenger seat...
Quick Reply: Power Seat Wiring
