Monsoon Subwoofer Question.
Old 06-05-2011, 01:56 PM
NEILZVETTE's Avatar
Default Monsoon Subwoofer Question.
My factory subs are toast. Unless someone is looking to sell me a set of there stock ones cheep I intent to put a set of the Kicker 6.5 subs in. As this is in a SS I found that they are 2 ohm just like the originals. Anyone see an issue with using these?
Kicker CVT65 6.5" Subwoofer Single 2 Ohm 150 Watts [10CVT65-2]
View detailed images (3)
List Price: $129.95
Price: $59.95
You Save: $70.00 (54%)
Shipping Quote
Shipping to 61537 = $10.57
Change Your zip code
View all shipping options
add to cart
Quantity
In Stock & Ready to Ship!
| More
* Description
* Specifications
* What's included
* Reviews
* Policies
* Related Products
Kicker CVT15 CVT 15 Inch Subwoofer 2 Ohm
The Kicker Comp VT subwoofers are designed to work in tight spaces with only minimal mounting depth possible. The CVTs provide about the same amount of bass as the CVRs but with about half the mounting depth.
Authorized Kicker Dealer
* Kicker CVT65 6.5" Subwoofer Single 2 Ohm 150 Watts [10CVT65-2]
* SKU: 10CVT65-2-N
o RMS Power Handling (Watts): 150
o Peak Power Handling (Watts): 300
* Subwoofer Size: 6.5 Inch
* Basket Material: Steel
* Frequency Response: 25 - 350 (Hz)
* Hole Cutout Diameter: 5-9/16"
* Impedance: Single 2 Ohm
* Mounting Depth: 2-7/8"
* Recommended Ported Box Cubic FT: Not Recommended
* Recommended Sealed Box Cubic FT: 0.20 - 3.0 (CU. FT)
* Sensitivity (dB): 84.6
* Surround Material: Santoprene Rubber
* This item is New
* 1-Year Manufacturer's Warranty
* 90-Day Half Price Car Audio Warranty
* Kicker CVT65 Product Manual
* Kicker Authorized Dealer: Authorized Kicker Dealer
Old 06-06-2011, 10:22 AM
Save the manuals!
wssix99's Avatar
Have you searched or read the sticky on this? Depending on the type of radio and type of car you have, you could be heading to a very bad place with this choice...
Old 06-06-2011, 09:29 PM
KEE AUDIO's Avatar
They are 2ohm but they also are shallow mount and like most shallow mount subs they lack bass. Even a 4ohm sub sounds better then those Kickers and make more bass. They have almost no xmax...linear excursion because of the nature of the way those are made. The cone is moved forward to allow for less depth which also takes away from bass output to an extent. I am not a fan of them at all. I have access to them as well...I just don't use them since there are better options in the same price range.
Everyone seems to get too caught up with the impedance of these speakers instead of reading what has been used successfully by other members.
Quick Reply: Monsoon Subwoofer Question.
