416 Rebuild -- AutoTec Pistons
Has anyone used these? If so, results please. I hope so, as their part# 1000418 is going in my engine along with AT4075 rings.
http://www.racetecpistons.com/at_products/index.htm
See if you can guess what the piston/wall clearances were on this setup.
These were the old Diamond pistons. To give you a clue, the builder used a 0.004" clearance on the mains.
[IMG][/IMG]
[IMG][/IMG]
The pistons called for 0.0055, they were almost double that number.
The piston in the picture above is a DIAMOND piston. Their 2618 stuff calls for 0.0055. The new (4032, #1000718s) did in fact indicate 0.003".
[IMG][/IMG]
[IMG][/IMG]
