Balancer Installer tool stuck in crankshaft.
Help from anyone ???
I am in the middle of a cam install now. I am putting the harmonic balancer back on (LS3). I bought an M16 threaded rod (~1 ft long) and threaded it into the crankshaft. I have an M16 nut and 2 big washers for pushing the balancer on.
I got the balancer most of the way on and then tried to remove the threaded rod (so I can go the rest of the way with the old crank bolt). Problem is... the threaded rod is stuck in the crankshaft. I guess the M16 rod stretched from the force of intalling the balancer. Any ideas for getting it out?
Also, does the balancer need to be rotationally aligned with the crankshaft? I didn't notice a keyway like the old 350's used to have... so I figured it didn't matter.
I thought about that... but I would have to order a M16 nut. Lowes/parts store/walmart doesn't have them.
I have a bolt on there now... I just need a way to keep it still. I tried to gum up the threads on the end, but the nut just drives right over them. If I had a welder I would put a bead on it.
Guess I should postpone my dyno tune appointment tomorrow .
Just got a question. I am putting my balancer back on and was wondering the process. If i read correctly u just heat the balancer then put it on tighten it with a used bolt then replace it with another bolt and torque back down. Do u have to align the balancer with anything? Is there a key way? What keeps the balancer from breaking loose and spinning on crank? Thanks
There's no keyway and by the time you get the SOB back on you will understand why it don't spin. Make sure you use a tool to put it on, not a hammer.
