LT1 Carb Setup
Old 06-06-2011, 10:23 AM
Next level's Avatar
Default LT1 Carb Setup
Ok im done with this spider web of crap!
Im going to do a carb setup on my car, my old man is going to help me out setting it up being carbs are more his thing. However, i need alil help with this before i jump right in.
1. Which carb is best for a Lt1 car, its a 383 Brand new w/ 42lbs injector. when engine was dyno'd it put around 475 to the crank. So, which size carb should i go with and brand ?
2. I have the plate for the opti already but is there a special distibutor that i need because of the firewall, how it over hangs the motor and is there a special distibutor that i need because it will not be computer controlled anymore ?
3. Would a 2" warbird hood work with a carb setup or do i have to go to the 4" from VFN ?
4. Is there any wiring that i need to keep from the computer harness ?
5. I know many have done this, what manifold do i need ?
i understand the EFI setup is the best for these cars but at this point where im at, i just want the damn car to run
Any help would be great, the quicker the better.
Old 06-06-2011, 10:31 AM
draggin97s10's Avatar
converted vic, there are several would be a good choice for a manifold, but depending on what the cars purpose is you might want a dual plane? Id say a 850 double pumper, but itll need to be jetted accordingly. Im not sure what type of dizzy people are running but i have a pro billet msd that i was going to use im sure it would fit. The bolt holes have to be welded and redrilled on your vic for them to work with an lt1 or you can get the heads redone to match sbc bolt holes your choice. As for wiring keep what you want to keep, oil pressure, water temp ect.
Old 06-06-2011, 10:33 AM
Next level's Avatar
I would need a MSD, ignition box ?
Old 06-06-2011, 10:36 AM
Originally Posted by Next level
Just read on another forum
I need sometype of spline for the distibutor in the back of the manifold. any ideas ?
not sure what you mean. Thats where the dizzy goes.
Old 06-06-2011, 10:39 AM
Next level's Avatar
just answered my own question on that. you have to put the spline there when you run a opti. never mind on that.
Old 06-06-2011, 10:58 AM
Next level's Avatar
my post about LT1 stuff im selling from my FI setup
https://ls1tech.com/forums/midwest-c...l#post15005610
Old 06-06-2011, 12:01 PM
brngrhd's Avatar
I have a carb on my LT1 it runs pretty good but Im going o switch Intakes as my motor has lots left on the table. Id be willing to sell my intake and carb spacer if you want it. Im going to convert a super vic for my combo. 13:1 265 273 @ .050 AFR 210's
Old 06-06-2011, 12:04 PM
Next level's Avatar
i actually just picked up a holley 750 brand new for $125 bucks from a buddy of mine, the manafiold, plate, wires, and balancer for $400 for another buddy.
Need the dizzy and do i need the spacer ?
Old 06-06-2011, 12:27 PM
brngrhd's Avatar
What manifold did you get? As far as spacer depends on the manifold and purpose of the combo.
Old 06-06-2011, 01:24 PM
Next level's Avatar
Edlebrock 4 BBL
Old 06-06-2011, 02:09 PM
brngrhd's Avatar
Edelbrock 4 barrel manifold? Thought gmpp was the only intake......
Old 06-06-2011, 02:42 PM
93M6Formula's Avatar
I can't possibly focus on the topic in this thread because of your avatar....
Old 06-06-2011, 02:53 PM
Next level's Avatar
i get that every thread i make, there is always someone.
you should see my other avatars i have, to bad LS1tech is too clean about that stuff
Old 06-06-2011, 03:56 PM
i second that
Old 06-06-2011, 04:07 PM
1961ba427's Avatar
wait.....what??
Will converting from efi to carb attract more ( o )( o ) ???
Someone mentioned "dizzy" and I was thinking "yeah I'm gonna be if I keep looking at that avatar!"
Old 06-06-2011, 04:12 PM
Originally Posted by 1961ba427
wait.....what??
hahahaha
Old 06-06-2011, 05:20 PM
Next level's Avatar
wait.....what??
its not the carb that attracts ( o )( o ) , its the car.
Old 06-06-2011, 08:45 PM
brngrhd's Avatar
Im on my phone so i can't see his avatar. .... Bump for intake question. Is it the gmpp intake or what?
Old 06-07-2011, 08:47 AM
Next level's Avatar
its a edlebrock i believe, ill know for sure tonight. All i know is it came off my buddies LT1
Old 06-07-2011, 06:25 PM
Bumper Dragin Bird's Avatar
its a victor E single plane. i had the injector holes welded up. the bolt holes line up, just had to use offset washers and modified the holes to work. had it ontop of a set of AFR 195s lt4s. made good power. im going a different route. yes i sold next level the intake he is talkin about
Quick Reply: LT1 Carb Setup
