05 cts-v cooling fans speed?
I have an 05 cts-v, was wondering if the fans have a constant speed or if they have a high and low setting, mine seem to only run on a slow speed and seems to heat up when stopped. Thanks for any input!
I'm not sure if the fans have multiple speeds, but I think one may run and not the other... you can check the obvious stuff first... relays, fuses, and if a fan motor is frozen... with the ignition off just spin the blades to see if one is more resistant than the other.
yeah finally with the ac on i finnally heard them kick on high and today its maintaining temp, but before i was gettin up to 225 without ac when stopped like in a drive thru line and they werent kickin on high
There are LOW and HIGH settings.
These are easily changed in HPTuners... as well as the VCM controls allows instant toggling for troubleshooting.
