Drag Racing Tech - anyone have pics of there a4 crossmember modified for th350
skeeter99
06-06-2011, 07:09 PM
I posted this up in trans section and got 0 feedback im bout to do the th350 and i would like some pics of how people modified there cross member before i hack mine up. Thanks!
krissoto
06-06-2011, 07:54 PM
Well first off u might have had a lil better luck in the trans section. But to my knowledge u don't have to mod anything. When I switched I went to a body mnt tq arm, so I cld be wrong but to my knowledge it shld work. Long tail shaft, diff flywheel, everything else shld work. Oh lokar dipstick
krissoto
06-06-2011, 07:55 PM
Sorry bout the first line
skeeter99
06-06-2011, 08:27 PM
I posted it in trans section first and got no feed back so ur saying u used ur stock a4 cross member and did not have to change anything
AChotrod
06-07-2011, 04:50 PM
Hmmm I thought a M6 crossmember worked with some shims but not a 60e crossmember???
skeeter99
06-08-2011, 06:50 PM
i have also heard that but im trying to keep what i got and make it work i just would like pics to have a idea but i have not had any luck finding any
Mighty Whitey
06-12-2011, 04:06 AM
That's when doing a th400 or 80e swap.
A stock th350 tranny mount is roughly 2" forward of the stock 4L60e.
I took a stock 60e crossmember, notched the front, an welded in a piece of 1"x2" 1/8" wall box tube, cut the part the extends out of the crossmember on about a 30* angle so it would be easier to tighten the nut up.
Simple, effective, and cost me $0 and about 2 hours of work.
Mighty Whitey
06-13-2011, 12:41 AM
Here's my crude, but effective (read: CHEAP) th350 conversion crossmember for my car:
http://i2.photobucket.com/albums/y35/indigoblue94/d01369b7.jpg
http://i2.photobucket.com/albums/y35/indigoblue94/72f00166.jpg
http://i2.photobucket.com/albums/y35/indigoblue94/6ca78d62.jpg
I decided to use a standard 9" tailshaft th350, modify my stock crossmember for the tranny mount to work, and since I've got a UMI adj. Tunnel mount torque arm, I didn't need to use the factory tail housing for the torque arm to mount to. I just re routed the speed sensor wires to the ABS sensor in my 3 channel rearend. Adjusted the pulse per revolution, or pulse per mile (can't remember which it was) and changed the gear to 1:1.
Just to clean things up a bit, I made a billet aluminum plug with an o ring for the original gear driven speedometer drive in the th350.
The Lincoln sp100-T I was using was on the border line of being too small for this job. .023" hard wire is good for sheet metal, and thats about it IMO. Penetration was good enough for what I needed here, I'd liked to have had a welder that had the ass to burn in a little deeper with attest .035" wire.
Hope this helps someone out. If you're running a tunnel mount t/a, and can have your computer tuned readily, I'd do this and save $180 on the tailshaft conversion kit.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
