Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Cartek line lock problems C5
Old 06-06-2011, 07:58 PM
jpeyton1077's Avatar
Default Cartek line lock problems C5
I just got a cartek line lock put on my c5. When I press the momentary switch the first time it works fine. When I release the switch the front brakes stay locked. Ive checked the fuses, ground. When the switch was put in it was checked with a meter and it showed good. Could the switch have gone bad after or do I have other problems? Thanks.
Old 06-07-2011, 04:28 PM
scramblerman's Avatar
When I had mine in my car it worked like this. Push the switch down and release, the front brakes are now locked. Push in the switch the second time and release, the front brakes are now unlocked.
Sounds like everything works fine to me, you just need to hit the switch again and the front brakes will be unlocked.
Old 06-08-2011, 08:12 PM
I tried it several times and they still stayed locked! when the power cable was spliced into the switch you could hear the valve open and close. I was just thinking it was the switch, could the line lock valve be messed up? I havent had a lot of experience with line locks!!!
Quick Reply: Cartek line lock problems C5
