O2 sensor extension harness for LS7 crate engine?
Hi,
I have an LS7 crate engine and the GMPP controller kit for the LS7. I need O2 sensor harness extensions and ordered two from Corvette Central that was for the C6 Z06 corvette.
When I got them I realized that the connectors are different, the ones I got where square shaped and the ones I had where kind of triangular with one of the tips cut of slightly. Not sure if that description makes any sense but that is the closest I get
My own investigation suggest that the standard C6 seem to have 4 O2 sensors and the front two might have the kind of connectors I'm looking for but this is not verified yet.
Any ideas or suggestions about this?
Thanks,
Thanks,
Auto Wiring Solutions should be able to help you out. http://stores.ebay.com/Auto-Wiring-S...id=p4340.l2563
