Stall a high mileage transmission?
My 4l60e has around 135K on it. I have no problems with it and it shifts good. I recently dropped the pan and changed the filter and fluid and everything looked ok, no burnt fluid or metal stuck to the magnet.
There was a little sludge in the pan and i could feel a few small metal particles in the sludge.
Also added a 26K Hayden cooler in front the of a/c condenser
My question is would it be ok to add a mild stall 3000-3200 on a high mileage trans like this or would I just it blow up ?
Has anyone put a mild stall on a high mileage trans and what was their experience?
my trans had 130,000 on it and i put a 3200 stall in it and it worked fine. I loved it. If you havent got a stall yet i have a BDR 3200 stall 10" stall it a year old i gave 450.00 for it ill take 300.00. It has about 800 miles on it
pretty good. The company is out of new york. it worked really good in my car. it drop my 1/8 time by 6 tenths. The only reason im not using it is i went with a full manual 700R4 and it want work with that set up my email is mckelveyadam@gmail.com if you want any pics or anything.
The stall will be harder on your transmission and probably shorten its life. I don't know if I would drop the money on a brand new stall but if you can find a good used one that might be a better option.
Restricted User
Yea, there is no real way to know. If it appears your trans is in good shape and you have a good cooler to go with the stall I don't see why not. Like others said I would save some money just in case it does go.
193k miles on the clock now running with a 3600 tci that i bought used. just had it rebuilt before i installed it along with fresh synthetic fluid, a deep pan, shift kit, and a cooler. no problems yet, and ive had it on for a little over 10k i believe.
