Best heads/intake setup out there for a 402? $$$ is no object.
I would concur with the MAST recommendation if money is no object.
That being said, you probably will need more than 10 lbs of boost to get 900 rwhp. May want to consider going to an F series blower as well. Recommend you post this in the FI section - lots of guys there running AFR 225's with well over 10 lbs of boost.
Good thing money is not a problem - 900 rwhp in reliable form is going to consume a bunch of it.
I saw them. I need something that looks like it belongs on a show car. Like this one.
http://www.wilsonmanifolds.com/galle...lds.html?img=1
The Marcella is more raw and looks like it belongs on a race car.
I don't know anyone who hasn't been pretty dissapointed in the results with that manifold.
thats kinda what i was thinking, your going to spend a ton on heads and intake and spin that little d1 for all its glory and probably be disappointed with the results. I think you are better off scaling back your goals in terms of power or investing more in a better headunit.
If the cnc look is what you're after then that leaves Marcella out of the mix.
Both HRE and Wilson use a combination of cnc and sheetmetal on their Manifolds.
That Manifold in the picture is only one example of what Wilson makes. You would need to call them and go over your build so that the correct Manifold design can be made. This goes with ANY custom Manifold regardless of who you purchase it from...
I've been thinking about it and talked it over with some more knowledgeable builders. I want the F1, but I thought it was going to be too big and wild for street use on a 402. I know the F1 is louder, that's exactly what I want. The sheetmetal intakes are nice, but I will lose low end only to gain power over 6000. Not worth it considering its a street car. I want reliability and streetablity.
My options:
Use my 402, F1, 225cc heads,blower cam, Fast intake.
Save money, sell my 402, build a 427, F1, 245cc heads, blower cam, Fast intake.
LS1Tech Sponsor
Thanks, I appreciate it! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
