Small Block & Big Block Chevy Specific - How much does a BBC conversion cost?
UrSmked
06-07-2011, 10:38 PM
Approx. how much money does it cost to do this conversion. I already have the motor, but thats it. Its going in a '00 Trans Am.
cambirdracing
06-08-2011, 06:17 AM
Depends on how big your bank account is.
mm8ls1
06-08-2011, 02:42 PM
You can easily get away with not having to buy an aftermarket K member. If you go the motor/mid plate route. That should save you some money, but your labor will be involved. I think it will just be simpler to buy an aftermarket trans cross member depending on your trans choice.
I'm in the same situation you are right now with having a 427 superstock engine, powerglide, converter etc... I just need to find a 93-2002 firebird for cheap that is clean.
I will personally remove the factory LS1 K member and send it off to MPR to have it modified for a large aftermarket oil pan. I will also use the LS1's motor mounts existing holes for my engine limiters that will be mounted to the blocks mounting pads.
tektrans
06-17-2011, 01:25 PM
I have a BBC motor plate made specifically for 4th gen fbody installs if anyone is interested. it's from Burkhart. I also have a mid plate.
jts98z28
07-11-2011, 07:09 PM
i am looking into this as well info bump
Bbcpoweredz28
07-31-2011, 02:51 AM
I have a third gen but. I used factory motor mounts for the SBC. And only needed an oil pan to clear the kmember. For me it was practically a bolt in lol.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
