PRC 227's and MS4 Graph Added
Old 06-07-2011, 11:39 PM
CNTLSE 1's Avatar
Default PRC 227's and MS4 Graph Added
1998 TA PRC 227's and MS4. Ported 92mm FAST Intake UMI 92mm TB 42LB injectors Racetronix pump U/D pulley stock rockers stock 10 bolt and 4.10 gears. Main stuff
480HP/409TQ at Speed Inc today with a temp of 99Deg at dyno time. I'm happy
Old 06-08-2011, 03:05 AM
CUR4VNM's Avatar
Congrats on some really great power, i bet it pulls hard. Do you have a graph you can post?
Old 06-08-2011, 04:00 AM
itsslow98's Avatar
Wow thats impressive.
Old 06-08-2011, 06:55 AM
CNTLSE 1's Avatar
have a graph will have to work on getting it uploaded
Old 06-08-2011, 07:42 AM
Cold Zero's Avatar
Congrats .. A4 or M6 ?? either of them it still great numbers on SEB
Old 06-08-2011, 07:56 AM
CNTLSE 1's Avatar
Its an M6
Old 06-08-2011, 08:00 AM
mercccc's Avatar
nice numbers. im def considering these heads for my motor in the future. thanks for sharing
Old 06-08-2011, 08:11 AM
CNTLSE 1's Avatar
the 215 could be considered also. I went 227 since I have a wet nitrous kit sitting on the garage floor for it. Just need time to install
Old 06-08-2011, 10:39 AM
LS1 SPEED INC.'s Avatar
Glad to hear you are happy and thanks again!
Old 06-08-2011, 10:42 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I'm glad you're happy with your numbers! Looking forward to seeing that graph
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-08-2011, 12:56 PM
Samer's Avatar
Congratulations, great results !!
What's the compression? and are those numbers on a dynojet or Mustang dyno? SAE or STD?
Waiting for the graph
Old 06-08-2011, 01:20 PM
MYSTIC-1SC's Avatar
Congrats on the numbers! Makes me anxious to see what my results will be!
Old 06-08-2011, 05:26 PM
mike c.'s Avatar
put a 12 bolt in it and drop 20hp. Do you 1/4mi race or just from a roll? Nice power.
SAMER-I believe he said speed inc dyno days so it's a dyno jet. if it were a mustang dyno he may of lost 15-20hp.
Old 06-08-2011, 06:36 PM
Wildside's Avatar
nice numbers stock bottom end
Old 06-08-2011, 10:43 PM
chrs1313's Avatar
Very nice not bad at all...what head gasket and cc size?
Old 06-09-2011, 06:18 AM
CNTLSE 1's Avatar
62cc chambers and stock GM head gaskets. Having trouble getting the graph scanned
Old 06-10-2011, 02:19 AM
venom ws7's Avatar
very nice Congrats..
Great work on tune Speedinc and great work on the package TSP..
Old 06-10-2011, 03:20 AM
skatnkidd's Avatar
Sweet numbers! The setup I'm putting together is very similar, just with a FAST 102/NW102 ported and 402 bottom end. Your results make me feel a lot more confident on the build. Why all the bashing from members saying rearend swap -20hp, dyno another -20hp, the temp was also 99* when it was done. Maybe that put the power down too? Give the man some respect and keep the BS out of his thread. Post up that graph dude!!
Old 06-10-2011, 06:41 AM
mike c.'s Avatar
most dynos correct the numbers for the heat and a 12bolt will drop power. is it bs,no it happens..
Old 06-10-2011, 01:23 PM
TXZ28LS1's Avatar
Great numbers!!
Quick Reply: PRC 227's and MS4 Graph Added
