Rear steam on l92 heads
Old 06-08-2011, 02:46 AM
colorado808's Avatar
Default Rear steam on l92 heads
I'm wondering if anyone else has their rear steam block offs already blocked. As you see in the pic there's only a hole for the screw and the dowel cannot go in to seal...do I still need to block this off? I didn't want to drill it if it doesn't need to be and I didn't want to remove heads either. Any help appreciated.
Old 06-08-2011, 11:48 AM
blake b's Avatar
You need these. I don't know the part number for the actual apparatus but the GM part number for the seals are 12551933 (air bleed gasket plates). They are the little plate on the end. You can barely see the rubber o-ring that goes around the dowel that does the sealing in the plate.
Old 06-08-2011, 12:11 PM
LS1MCSS's Avatar
I think GM blocks off the rear steam holes on the newer L92 heads. If yours have already been blocked then you don't need to do anything else there.
Old 06-08-2011, 12:47 PM
Those are the ones that I currently have but they don't fit because there is no provision for the steam hole, only the screw in.
Old 06-08-2011, 09:05 PM
S10xGN's Avatar
As LS1MCSS said, yours are already factory plugged so you need to do nothing else.
Old 06-08-2011, 10:20 PM
Zbinkley's Avatar
So you can block off the rear steam ports? I was just going to mod my steam tubes with a hose looping over the intake. but that would be sweet if i didnt need to do that.
Old 06-09-2011, 07:55 PM
S10xGN's Avatar
GM started blocking the rears when they went to the LS-6 manifold.
Old 06-09-2011, 08:29 PM
LS1MCSS's Avatar
The newer L92's heads are plugged in the head.
Old 06-09-2011, 10:43 PM
oakley6575's Avatar
That is sweet. If I order LS3 heads from the dealership right now, part number: 12629063, do you guys think they will come blocked off in the rear?
Old 06-09-2011, 11:38 PM
MattSapp95_T/A's Avatar
Mine didn't....
I had to use the block offs that were on my 317 heads...
Old 06-09-2011, 11:39 PM
oakley6575's Avatar
Dang. But I do think thats cool that they are blocking them from the factory
Old 06-10-2011, 02:36 AM
DietCoke's Avatar
My LS3 heads don't have steam pipe connections.
Old 06-10-2011, 08:37 AM
Thats weird...do you have a pic?
Old 06-10-2011, 04:01 PM
DietCoke's Avatar
Ill doublecheck my clutch install pics when I get home, that's when I noticed it. Might just be a factory installed ls3 thing.
Old 06-10-2011, 07:51 PM
93Z2871805's Avatar
Setup for block-off plugs here, my LS3 (with blue springs) heads were bought about a month or two ago (but who knows how long they were on the shelves).
Old 06-12-2011, 12:40 PM
litle88's Avatar
I just bought a set of LPE cnc'd heads and they came with the steam holes tapped and ready for installation on both sides so no block offs hear.
Old 06-13-2011, 12:19 AM
ultradriver10000's Avatar
Wouldn't you rather allow the heads to vent?
Old 06-14-2011, 05:55 PM
oakley6575's Avatar
Just received my 0821 LS3 heads and the back ports aren't blocked.
Old 06-15-2011, 09:36 AM
1A Dan's Avatar
mine were used when i got them and were blocked off. i wanted to run the steam tubes in the front and back, so i used an old truck steam tube block as a guide and drilled em out.
Old 06-16-2011, 12:57 PM
litle88's Avatar
Show me your set up please. Ive been debating this all spring and I decided to pull the trigger.
Thanks
Quick Reply: Rear steam on l92 heads
