BowtiePryd
06-08-2011, 08:51 AM
FastFatBoy and I had a blast at Barber. This was a shake down run for my car, so I definitely found a few bugs to work out. The last session the upper radiator hose blew out of the pump which of course put water everywhere (including under the tires). I think it is just a bad pump, but if anybody has seen anything like this before let me know. Quick rundown of the car: '99 Camaro, Forged 347, TFS as cast heads, Fast92/92, Comp Cam 236/238@ .50 .612/.612 lift approx 450 RWHP. Aftermarket control arms front/rear, Strano sway bars, Koni SA shocks, Strano springs, Watts link. The car weighs 3173 w/o driver. http://www.youtube.com/watch?v=svoTy_Gkhmc
http://i211.photobucket.com/albums/bb61/GNBS/99Camaro440.jpg
http://i211.photobucket.com/albums/bb61/GNBS/99Camaro445.jpg
BlackDemonSS
06-09-2011, 02:42 PM
Incredible! Your car sounds bitchin. How do you like your suspension setup? Is there anythign you would change to it if you could?
BlueBird346
06-09-2011, 11:42 PM
Love seeing an F-body on Barbers! I live 30 minutes from there. Id love to drive my car on the track, whos track day was this? BMWCCA?
X2 for imput on your suspension.
BowtiePryd
06-10-2011, 06:35 AM
Thanks for the compliments. I am extremely pleased with the setup on this car. I set the shocks per Sam Strano's recommendations and the car handles very well. I am no expert, but there is nothing "I" can adjust or change to make the car handle any better. So to answer the question, there is nothing I would or plan to change on the suspension of this car. A few things I forgot to add: the car has a stock 10 bolt rear with a 3.42 gear and a Detroit TruTrac differential. I am currently running stock C5 Z06 wheels with a set of Nitto NT05 tires (275/40/17 front -295/35/18 rear). Here are a few more pics of the car:
http://i211.photobucket.com/albums/bb61/GNBS/99Camaro399.jpg
http://i211.photobucket.com/albums/bb61/GNBS/99Camaro402.jpg
http://i211.photobucket.com/albums/bb61/GNBS/99Camaro436.jpg
