Stock Suspension vs Coilover Suspension Question
Old 06-10-2011, 02:01 AM
MAYH3M's Avatar
Default Stock Suspension vs Coilover Suspension Question
Hey Guys,
I currently own a Roller Project (98 Z28) and it has QA1 Coilovers in front (Unknown Spring Rate) and QA1 Shocks in back.
I'll be quite honest, I don't know too much about Coilover Struts to decide whether I should keep the Fronts and pickup a Rear Kit, or switch back to the stock Suspension.
All I know, is that when the car is finished, I would like it to handle wonderfully on an autocross/road racing track, hook decently on the street/strip and be able to drive around town no problems.
Can anyone shed some light on the topic?
Thanks,
Jim
Old 06-10-2011, 10:46 AM
libertyforall1776's Avatar
There are no struts on 4th Gens, they are coil-over (in front) shocks stock.
Start out reading:
https://ls1tech.com/forums/suspensio...up-review.html
https://ls1tech.com/forums/suspensio...eal-world.html
Old 06-10-2011, 05:37 PM
JD_AMG's Avatar
Originally Posted by MAYH3M
Hey Guys,
Thanks,
Jim
^ What the above posts says + QA1s are drag shocks, they are only going to hurt your handling and ride quality. Look into handling/sport shocks like Bilstien or Koni, and stay away from non-gas charged drag stuff like Afco, QA1, Strange etc.
What you are looking for has been covered many many times, search this forum.
Old 06-10-2011, 05:57 PM
99Bluz28's Avatar
Handle wonderfullyand QA1 shocks, just don't mix.
Been there, done that!
Old 06-11-2011, 06:47 PM
CHRIZ28's Avatar
So is there not a coilover that will handle well?
Chris
Old 06-11-2011, 07:48 PM
99Bluz28's Avatar
It depends on how much you're willing to spend.
Old 06-11-2011, 09:39 PM
CHRIZ28's Avatar
Any more info? You can pm me if you'd rather. I just really like the adjustability of my QA1's up front, but wish they were a better handling shock/spring combo. I was planning on going with the koni/strano setup, but would much rather have coilovers all around.
Chris
Old 06-11-2011, 10:18 PM
Is anyone really making rear 4th Gen coil-overs?
Old 06-11-2011, 11:22 PM
Cumbias's Avatar
Edelbrock makes front coil-overs
Old 06-12-2011, 02:22 PM
CHRIZ28's Avatar
http://www.spohn.net/shop/1993-1997-...le-Shocks.html
Chris
Old 06-12-2011, 04:22 PM
MAYH3M's Avatar
Well, the point of the question here was to see what is more ideal, the stock suspension or keeping the current setup.
Old 06-12-2011, 04:52 PM
JD_AMG's Avatar
Chris
Here are some adjustable coilovers made for handling:
http://www.stranoparts.com/partdetai...D=20&ModelID=7
You can also look into race bilstiens or penske shocks (both are custom valved for you).
http://www.unbalancedengineering.com/Camaro/
Or you can put the ground control adjustable coilover sleeve over your front shocks, thats a much cheaper alternative. And you can buy an adjustable spring perch that mounts to the axle and lets you adjust height (I think this is a ground control piece too).
There have been numerous threads about why running a coilover stlye in the rear is looked down upon, mostly because the mounting point is not strong enough.
Quick Reply: Stock Suspension vs Coilover Suspension Question
