Burning oil when switching to 8 cyl mode
Old 06-10-2011, 11:03 AM
steves ls6's Avatar
Default Burning oil when switching to 8 cyl mode
I notice when cruising on the expressway at about 70-75 mph for a few miles that when it switches to 8 cyl mode my exhaust blows out a big puff of blue smoke. Anyone ever experience this?? My car also goes through a quart of oil every 1500-2000 miles.
Old 06-10-2011, 02:09 PM
JC05GXP's Avatar
yep, i found the same thing on mine. These engines are known to burn oil when in 4cyl mode. I burn a quart every 3kmi or so
Old 06-10-2011, 02:13 PM
babbage1109's Avatar
It's a known issue with those engines. It's the dod system. Get it disabled and your problem will go away.
Old 06-10-2011, 02:22 PM
LS1Tech Sponsor
06MonteSS's Avatar
yep ^ ^ ^
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 06-10-2011, 02:43 PM
Model16's Avatar
Yes disable DOD as soon as possible!
Youll lose about 1-2 mpg on the highway, city stayed the same for me about because its rarely in 4 cyl mode then anyways..
When I had 4 cyl mode I would burn a quart or so every 5k, sometimes a little more..
I disabled DOD about a month or so ago, and got an oil change the day before I disabled it..I have not lost any oil since...Ive put on I think roughly 3.5k to 4k miles since.
Old 06-10-2011, 03:21 PM
steves ls6's Avatar
Is it as simple as getting the computer reprogramed to disable it? If so where can I do it around NW suburbs of chicago?
Old 06-10-2011, 03:26 PM
Just take it to a dealer. Or speed Inc in Schaumburg
Old 06-10-2011, 03:37 PM
XFiveLiter's Avatar
Mine does the same thing, made a thread about it a while back. I'm using about a quart every 1k
Old 06-10-2011, 07:11 PM
cderry's Avatar
Mine just started to do this and since I'm under gmpp still till the end of the month it's going to the dealer. I saw a post involving something about this issue that gm actually acknowledges this problem. Found the pdf for it. http://ww2.justanswer.com/uploads/Bl...alve_cover.pdf
Old 06-10-2011, 08:18 PM
They acknowledge it but it'll take a year for them to fix it right. After all the oil tests and everything. Dod isn't that special. It's simple just to disable it an forget it
Old 06-11-2011, 12:27 AM
cacicgtp7's Avatar
I just posted this on clubgp, but I'll post again anyway, with at least my experiences and I know quite a few other people on this board:
"If you're using Mobil 1, it's known to burn faster than any other synthetic on this car (it's also one of the thinnest synthetics to slip through the piston rings). Check the ls1 forums (ls4 sub forum) for more details. Other synthetics seem to burn slower, but yes there is still consumption no matter what on these in 4 cyl mode. Since I switched to Pennzoil Platinum, I consume only 1 qt every 3,500-4,000 miles as opposed to the 2 qts every 2,000 miles when I was using Mobil 1. Just my 2 cents."
Old 06-11-2011, 01:05 AM
LS1Tech Sponsor
06MonteSS's Avatar
I've used Mobil 1 oil exclusively in my Monte SS since 9000 miles... I'm now at just about 109,000 miles...
never burned 1 drop....
my DOD is disabled - has been for the past 5.5 years... 4 months after I bought the car brand new...
it's the DOD causing the issue... NOT the oil....
__________________
Old 06-11-2011, 05:07 PM
cacicgtp7's Avatar
I know it's the DOD, but Mobil 1 didn't help. I'm just reporting my results and I haven't touched the DOD, the fact that I burn an entire 1 qt less in more miles says something. I know there's others that have reported the same problem with Mobil 1 in this car. But yes the DOD is the main culprit, but just giving an "imo." lol
Old 06-12-2011, 12:35 AM
gxp-miller-gxp's Avatar
when disabling dod, dont you have the risk of a lifter collapsing? or no?
Old 06-12-2011, 01:12 AM
No. All it does is stop the engine from disabling 4cylinders. It will run as a norm v8
Old 06-12-2011, 06:44 PM
steves ls6's Avatar
thanks for the info. Now I have to decide what would be better to go to the dealer or speed inc?
Old 06-12-2011, 09:47 PM
Call and see who can do a better deal. Maybe if you need a tune I'd go to speed and kill two birds with one stone
Old 06-15-2011, 08:55 PM
4doorSS's Avatar
Thank Goodness for this forum I was wondering why this was happening I run pennsoil and it never fails when the counter gets around 60 percent im a quart low even when i babied it so im guessing dealer or buy a tuner to disable the DOD?
Old 06-15-2011, 09:05 PM
smokin06impala ss's Avatar
The oil burning problem on my Impy stopped when I disabled DOD
Old 06-15-2011, 11:33 PM
1CL3ANSUP3RSPORT's Avatar
DOD kills me,probably one of the few members with DOD still.The dealer can delete DOD for me?
Quick Reply: Burning oil when switching to 8 cyl mode
