Spohn double del sphere panhard bar length
I'm try to figure out how long the bar is excluding the del spheres. I just swapped out the spohn double poly panhard. I'm trying to adjust the new one on car now to match the setting to the poly, I know I should have matched it off the car, but I didn't think about it. I feel I'm running out of threads therefore they might just pop out whether it be from me or driving later. Any help would be appreciated, thanks.
If you are not happy with ^^^^ , you might consider calling Spohn's tech line. They are very helpful. Since my SS has stock springs, I installed my rod ended PHB as it came from Spohn which is set at stock length. I did check it against my stock one to be sure though.
