underdrive pulley keyway?
i'm in the middle of a head/cam swap. i just got done pulling off the stock pulley and i noticed there is no keyway on the pulley or crank.
the pulley im putting on is an SLP, it has a keyway in it.
is this an issue? should i just put it on however? there are degree markings on the SLP pulley, so i would assume it would matter.
or should i stop having beers while i work on my truck?
'01 silverado 5.3L, 2wd, SCSB
thank you.
thank you.
