Torque spec for torque arm to torque arm bracket bolts?
What bracket are you talking about the one that goes around the poll bushing and bolts to the transmission. I am assuming its a full length and not a short one.
If you are talking about the bracket that bolts to the transmission just get them tight but be careful with the top bolt that bolts into the tail shaft it is easy to strip out seeing as how the housing is aluminum.
Actually the specs in the Haynes manual are for the bracket to rear housing bolts. The torque arm is an aftermarket piece and isnt in the manual. I am going to set it at 100 ft/lbs for now, but I would assume there must be a spec on it so that you don't bind the rod ends in the bracket. It's not like the bracket rotates on the rod ends except when you adjust the pinion angle, so I think 100ft/lbs will be fine. But if anyone knows the actual spec, I would like to write it down for the future. Thanks
Yes, those are all for a stock torque arm. On an aftermarket adjustable unit, the rear bracket is bolted to the tubular arm. Those two bolts are not part of the stock unit. That is why they are not listed in any manual. And my BMR installation sheet doesn't list a spec for those bolts. It only has the 2 housing bolts listed.
