What starter to use with long tubes?
I had to bring my car into the shop because it would randomly start and not start. After doing some other stuff they are telling me it's the starter and the only one that will fit is the ac delco and it's $400. Will anything else work? They tried the autozone one and said they couldn't get it to fit.
just get a delco, you can find em a little cheaper if u search around
http://www.maniacelectricmotors.com/camaro.html
Wrapped headers will keep engine bay temps down as well as exhaust velocities up. I would expect minimal gains.. Performance point it isn't worth the money unless you have nothing else to do. I'd say gains would be about the same as the coolant bypass mod maybe a bit more.
I'd say If you have shitty looking headers/etc... It would be about the same as coating, littpe heaped but also a littoe more work.
