Vibration after s60 install? help
I finished up my s60 install today. I have a vibration when coasting and decelerating. No vibration when under acceleration even slight acceleration has no vibration. When coasting downhill with the trans out of gear, it was worse. Gears are quite at all speeds, no whine on accel or decel, so I dont think it anything inside the rear. Any ideas? I'm thinking of changing my pinion angle closer to 0 to see if that helps. Only thing that I could think of that would cause vibration on only decel and coasting. I had no vibration issues with the 10 bolt I took out. Only parts changed were the rear and driveshaft. Thanks
Ryan
Ryan
Actually, it appears that the driveshaft i was sent from strange might be too short. Luckily I noticed before there was any major damage. I am waiting on a reply from them to see if that is indeed the problem and how they will resolve it. Anyone know the correct length for the driveshaft with a t-56 and s60?
Thanks
Ryan
Thanks
Ryan
