98' TA, AFR 205s + 224cam + LASHWAY 3200stall
Old 06-11-2011, 09:15 PM
Josh@Lashway's Avatar
Default 98' TA, AFR 205s + 224cam + LASHWAY 3200stall
a quick build we did on our very unforgiving mustang dyno:
1998 TRANS AM 80K MILES
AFR 205s slightly milled
224/224 114LSA
FAST 78
DUAL VALVE SPRINGS
LASHWAY 3-PIECE PUSHRODS
STOCK TRANS
LASHWAY BILLET SERIES 3200 STALL
402/346 unlocked
415/375 locked
Old 06-11-2011, 10:01 PM
VincesSS's Avatar
Ditch that 78mm fast and you'll pick up at least 200hp! lol jk! Those intakes still work well.
Great numbers, that thing will shine at the track!
Old 06-11-2011, 10:08 PM
lemons12's Avatar
Why so small on the converter?
What is he shifting at?
Looks like a nice fun street car!
Old 06-11-2011, 11:01 PM
1989GTA's Avatar
Looks like the power was still climbing at 6400.
Old 06-11-2011, 11:17 PM
lemons12's Avatar
That's why I inquired shift point. Odd to see that setup still climbing that high.
I'm guessing It stopped there for longevity.
Old 06-12-2011, 06:59 AM
LS1Tech Sponsor
Slowhawk's Avatar
Looks good. The 114lsa and intake push the peak higher in the rpm range.
Old 06-12-2011, 08:47 AM
ctd
ctd's Avatar
What are Lashway 3 piece pushrods?
Nice set up BTW!
Old 06-12-2011, 10:48 AM
Mazzenger's Avatar
Pretty strong.
Old 06-12-2011, 10:58 AM
Nice set up BTW!
we have our own insanely strong pushrods and as it says, they are a true three piece design with tool steel ends and a chromoly center.
Old 06-12-2011, 11:45 AM
lemons12's Avatar
I have a 226/228 .588 114, although coupled with an ls6, mine dies off before that. I shift around 6300.
Old 06-12-2011, 11:58 AM
ctd
ctd's Avatar
Tx's, I think I have valve train issue, I suspect if you have developed a specific pushrod you maybe familiar with what I've got going on. I will call you tomorrow during your business hours.
Old 06-12-2011, 12:35 PM
3YLSYKR's Avatar
Not bad, good numbers.
Old 06-12-2011, 03:38 PM
s346k's Avatar
torque seems crazy low unlocked esp for a milled head/baby cam car.
i'm sure it will run at the track. nice numbers.
Old 06-13-2011, 08:09 PM
DSRE's Avatar
I bet that cam is installed at least 2* retarded, otherwise Low end tq and hp at 3000rpm would be higher and it would peak earlier JMO
Old 07-20-2011, 09:22 AM
DannoWS6's Avatar
Those #'s aren't bad. Looks about right to me.
