Conversions & Hybrids - Th350 VSS question
Dillon79scotts
06-12-2011, 02:41 AM
I havent really heard or seen Anyone say much about there stock vss,
My question is, i am running a 5.3l, getting computer flashed to delete a bunch of stucx, but i saw on lt1swap.com that he is saying you need a electric vss pulse to the pcm,
Is this true? Says it can effect fuel mileage, idle issues. Has anyone done this before and is it a must?
Dillon79scotts
06-12-2011, 02:43 AM
*stuff* not stucx
the_merv
06-12-2011, 11:48 AM
Depends on how you have the tune..if you set it up for a standard then it might not matter in a way. There are conversion kits out there.
I'm about to put a TH350 into my car and I have an extra T56 Reluctor layin around, I'm looking into modifying it to work on the Tailhousing with a VSS.
deuce4935
06-12-2011, 11:56 AM
NOOOOOOOOOOOOO!!!!!!!! Why Merv why? Tell me you didnt hurt the T56 again. To the op, most guys run a vss to keep the engine from stalling when you come to a stop and to help the idle. Dakota Digital has a setup thats been used countless of times as well as JagsThatRun.com
the_merv
06-12-2011, 01:33 PM
Lol..that's the Track Trans, the T56 will still be in it for the street fun..:drive:
Slow 346
06-12-2011, 06:05 PM
I have a Turbo 350 in my Nova swap and im not running a VSS. The car starts, idles and runs fine. Even when coming to a stop.....no issues at all.
get the 40 tooth wheel, sensor and tailhousing from an early to mid 90s 2WD truck that has it.
those 4L60 model tailhousings bolt to a 6" tail Th350 or bolt to a 9" tail w/ a spacer.
w4625
06-12-2011, 08:35 PM
Does the same apply to the 700r4?
deuce4935
06-12-2011, 10:16 PM
Depending on the year, some of the 700r4's had tailhousings with vss.
the_merv
06-12-2011, 11:06 PM
That thought crossed my mind, where did you get the spacer?
welldonecj7
06-14-2011, 02:11 AM
what about if you have a 4wd trans? Just one of the dakota digital ones?
Monza355
06-14-2011, 06:26 PM
I put a th350 in my Monza with the LS1 with no VSS and never had any problems.
1FSTLS1
06-14-2011, 07:09 PM
I have th400 and motor wants to die comming to a stop. Idles and drives fine. I am hooking mine up tomorrow.
That thought crossed my mind, where did you get the spacer?http://www.ls1tech.com/forums/automatic-transmission/1327280-th400-swap-4l60e.html
what about if you have a 4wd trans? Just one of the dakota digital ones?get the 40 tooth wheel, sensor and adapter or t-case? from an early to mid 90s 4WD truck that has it.
the_merv
06-14-2011, 08:51 PM
Bad ass..:)
