General Maintenance & Repairs - weird head light issue with trans am
BennyB
06-12-2011, 02:45 PM
for some reason after i got dyno tuned yesterday when i go to lock or unlock the car via key fob the head lights pop up then go back down right away and one is making a grinding noise like the motor is still running after the head light is already down. Could this be a BCM issue? bad ground maybe?
1996firebirdformula
06-12-2011, 02:55 PM
Headlight Gear is stripped its plastic piece of crap one. :bang:
Search it on here headlight gear.
http://www.bfranker.badz28.com/headlightfix/#headlightgearfailures
02v8ta
06-12-2011, 02:59 PM
Also go read the headlight sticky on the firebird section.
BennyB
06-12-2011, 06:32 PM
thanks for the responses guys. i know i should have done a search first, but this got me a quick answer.
wssix99
06-13-2011, 10:54 AM
You may also want to go with the Cardone motors before making a gear switch. They have a different case, which is easier to service the gears in the future.
Also, if you go with metal gears, be sure to get the ones with the rubber inserts so you don't strip those out, too.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
