what big cam to use with ac
Old 06-12-2011, 03:32 PM
lawndragster13's Avatar
Default what big cam to use with ac
what is the biggest cam could i use with my ac still to work without over heating and changing to much to the engine.it's a 01 ls6,p&p heads,vavles,springs.ported ls6 intake,85mm tb,525/236 cam,upgraded fuel system,headers,xpipe,flowmasters,4l60e auto trans upgraded,3200 yank stall,355 gears,i don't know to much about this.i live in south la. it's very hot here.
Old 06-13-2011, 07:20 AM
Internet Mechanic
BlackScreaminMachine's Avatar
In general with proper driveability tuning and taking safety steps like water wetter and messing with the fan temp on/off parameters you can run as big as you like and thats in the MS4/T-rex range.
A properly working cooling system should be fine in almost all heat ranges. When you start boosting a car the under hood temps soar and thats when you need to worry about detonation. N/A I see no issues.
Old 06-13-2011, 11:05 AM
Arctic2002ss's Avatar
I have an LS3 with a 227/239 629/623 cam. I put almost 1,000 miles on it this weekend with the AC in 90+ weather. It did get a little warm once while sitting idling on hot blacktop with the AC on. No issues otherwise.
Old 06-13-2011, 11:08 PM
garygnu's Avatar
what trans?do you have a after market air intake system ?you match cams to gears ,weight and stall if auto.talk to the people at TSP for a cam pkg that will fit your needs.
Old 06-15-2011, 06:17 AM
thanks guys for the info
Quick Reply: what big cam to use with ac
