Central Illinois Tuners? Suggestions!
Old 06-12-2011, 11:12 PM
NEILZVETTE's Avatar
Default Central Illinois Tuners? Suggestions!
Picked up a 2001 SS Camaro with a six speed. Motor is stock other ebay full lengths, 3 in y pipe with 3" cats and Procharger that was dealer installed and dynoed out at 415hp. That seems pretty weak for a supercharged car. I recently had the dual/dual SLP system taken off and replaced with a Dynomax Bullet 3" catback. It has since thrown a "lean on bank one" code twice.My suspusion is this exhaust is flowing much better than the last. I have considered bumping the boost on the car to what is considered safe on a stock block. What would one guestimate that power output to be. What would one expect to pay for a tuner to put a larger pulley and dyno tune it correctly. Also considered a 4:10 gear swap and keeping the motor very safe. Anyone that you would recommend near me. I am about 2 hours southwest of Chicago.
I expect to keep this a street car (but weekend toy only) with maybe a few runs at play days in Cordova raceway and such. Goals are to lower suspension and get the car to be an all around car that handles respectfully. I have had the weld in frame connectors done as this is a T-Top car. Intending to go to a lowering spring with an adjustable panhard bar. What else would you guys suggest?
Old 06-14-2011, 12:03 AM
NEILZVETTE's Avatar
No suggestions on good tuners in this area?
Old 06-14-2011, 08:44 AM
CalEditor@PCMCalibrators's Avatar
We have a location in Rockford
Old 06-14-2011, 11:49 PM
NEILZVETTE's Avatar
Actually working in Rockford. What is location and hours?
Old 06-15-2011, 08:57 AM
I will PM you the details
