Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Current mileage & maintenance
Old 06-13-2011, 01:48 AM
wcryan's Avatar
Default Current mileage & maintenance
Let's get some current mileage on our old beasts along with warrantY stuff you had to fix along with non warranty
07 V 37,400
-Drivers side catalytic converter
-clutch position sensor
-rear diff seal
-cracked grille
-peeling buttons
Old 06-13-2011, 04:18 AM
GhettoTy's Avatar
05 w/ 55k
-rear diff at 35k
-wheel sensor
-peeling radio buttons
-starter
D Block's Avatar
06 77xxx
-motor
Do i win??
Old 06-13-2011, 04:55 AM
itsslow98's Avatar
Originally Posted by D Block
06 77xxx
-motor
Do i win??
All those truck motors are junk, thats why whisler's ls2 blew up as well......
jk **** happens
Old 06-13-2011, 06:33 AM
STAGEUP's Avatar
2005 51,000 miles.
Peeling buttons
Rear diff
Alternator making a whining noise
Sunroof rattle
Trunk struts weak
Old 06-13-2011, 07:05 AM
falke401's Avatar
2005 59,000 miles
Updated diff
radio buttons
shifter trim ring broke
Front passenger strut
Old 06-13-2011, 07:23 AM
.Houdini.'s Avatar
07 V 43,xxx
Not in order:
-3rd diff
-rear diff seal (x2)
-diff bushings
-motor mounts
-peeling buttons
-nav screen cover
-shifter
-spark plugs
-endlinks
-sway bushings
-starter
-sunroof
-sunroof leak
-a pillar molding
-rear sail panels
-headlights
-power steering flush/fluid replace for whine
-seat creak fix
-diff vent tube tsb (twice) for leaking diff fluid
-much more that I can't remember now.
Still under luxury CPO warranty until July 2012...THANK GOD! Running strong now and no current issues. Still love the car.
Old 06-13-2011, 08:38 AM
Skidmarcx's Avatar
04 with 64,700 mi... only had had it for three weeks and so far...
tune up and motor mounts (previous owner new about and compensated for)
bad catalyst (replacing with headers and high flows)
front shocks
peeling buttons
rebuild supercharger
Old 06-13-2011, 11:36 AM
Chris0nllyn's Avatar
05 w/60k
Motor mounts
(2) radios
pinion seal
passenger seat cover
1/2 synchros
headlight ballasts and bulbs
Both front struts
I know im forgetting something, the service writer printed me out 2 pages of service records...
Old 06-13-2011, 11:57 AM
chummmma's Avatar
05 with 131k... had it since 57k sept of 09
1 rear shock.
Old 06-13-2011, 12:06 PM
motaboata's Avatar
seems like you guys have alot of problems geesh
Old 06-13-2011, 12:19 PM
SoJersey05V's Avatar
I wish I had kept a list!
Old 06-13-2011, 12:28 PM
Slithering_Joe's Avatar
'05 V w/ 45,000 miles
In order of failure/replacement: (all under warranty)
- Original rear differential replaced, whining. Gen-IV installed & whines sometimes.
- Navigation/Radio replaced, peeling paint on buttons & *****
- Side view mirror switch, peeling paint on switch
- Hood chrome trim replaced, peeling chrome
- A/C pressure sensor replaced & connector replaced/repaired (open circuit)
- (2) tire pressure monitor sensors replaced (dead)
- Reverse lenses replaced, filled with water
- Power steering hose replaced, leaking
- Left & Right HID headlamp/washer assemblies, lens cracking & discolored
- (4) tires replaced/prorated under Michelin warranty, center tread-blocks wore down
- Front brake lines, recalled
- Engine mounts replaced (leaked and loose)
- Starter replaced, internal solenoid connection failed due to exhaust heat
- Starter turn-on lead and connector replaced (connector cooked by exhaust heat)
...besides all of the above the car is great!!!
Old 06-13-2011, 05:56 PM
jenks40's Avatar
Default oh yeah.
jk **** happens
Maybe, but it appears they come with truck diff's also...
06, 51k
Radio button wear
Passenger interior pull handle on door fell off
Pretty sure I need motor mounts.
The dealer I bought it from had to put a new clutch in because they sold it to an 80+ year old man that didn't know how to drive a manual. He put a few hundred miles on and traded for a new malibu...
I feel lucky. If I'd been to this website before buying the car, I probably would have bought a BMW.
Old 06-13-2011, 06:02 PM
wcryan's Avatar
BMW is a bad word on this website. Haha. And if you did get a Beemer then you would have to buy expensive snobby clothes too. And maybe a Ferrari watch. And gucci sunglasses. And last not but least. A hot gf that really doesn't like you, but only your car. I really hope there is a BMW owner reading this. Oops
Old 05-12-2017, 07:45 PM
JEFFCTSVMANW's Avatar
Default 06
O6 V 73K miles
Steering rack crapped out at 73K
that is only thing!
Old 05-12-2017, 09:44 PM
isis's Avatar
What did you replace it with, a time machine?
Quick Reply: Current mileage & maintenance
