removing baffles from exhaust tips
Old 06-13-2011, 11:00 AM
Anniversary "Z"'s Avatar
Default removing baffles from exhaust tips
Do they need to be cut out or how do you guys remove them?
Old 06-14-2011, 02:59 PM
bueller, bueller, buuuueeeeeelllllleeeerrrrrrrr?
Old 06-14-2011, 03:21 PM
TheJPGXP's Avatar
I haven't seen stock tips in about 3 years, could you be more specific? You mean the real pipes or the polished housing, or something different?
Old 06-14-2011, 04:33 PM
texasGXP08's Avatar
just replace the whole tips. 3.5" dual outlet tips can be had for cheap online. I got rolled ones on ebay for $70.
Old 06-15-2011, 09:43 AM
Well duh, that makes sense I think I got caught up in the DIY and lost some of my common sense. Thanks guys
JP, the stockers are nice polished tips but they have baffles inside them that squeezes the outlet down to about the size of dirtbike exhaust
EBay here I come!!
Old 06-15-2011, 09:50 AM
williamGT's Avatar
take the tips off and replace them....when I had my 08 GXP I had hooker aerochamber mufflers with the stock tips welded on, it was quite, so I took them off ad it was loud.
Old 06-15-2011, 11:27 AM
any particular ones that you guys buy? 2.5" inlet right?
Old 06-15-2011, 12:17 PM
94ss06gxp's Avatar
the stock exhaust pipe from the muffler to tip is like 2", and also from the rear Y split is like 2" also.
Old 06-15-2011, 12:53 PM
So would these be too large? Specs say they have a 2.5" inner diameter inlet
http://cgi.ebay.com/ebaymotors/NEW-S...Q5fAccessories
Old 06-15-2011, 01:43 PM
JessmoMonteSS's Avatar
I believe the stock piping is 2.25''
Old 06-15-2011, 04:44 PM
GXP25's Avatar
Don't you have to change out the mufflers as well? Our mufflers are offset and the tips tend to curve towards the bumper outlets. Not only that, but they're kind of flat near the muffler.
Old 06-15-2011, 04:51 PM
GXP25's Avatar
Much nicer tip.
Couldn't get them on due to the mufflers issue.
http://www.amazon.com/Vibrant-1329-D.../dp/B000MKA2WE
http://www.verociousmotorsports.com/...haust-Tip-1329
Got mine for $80.98 shipped.
Old 06-15-2011, 05:20 PM
WhiteGXP313's Avatar
i like the stock tips i just wish they stuck out of the bumper a lil
Old 06-15-2011, 07:23 PM
DavidGXP's Avatar
Cut the mufflers off and stright pipe it with new tips.
Old 06-16-2011, 06:09 PM
UR2NOZ's Avatar
Ahmen...what he said. Just did that and replaced the resonator with a Magnaflow Magnapack....exhaust sounds bad *** and almost silent when cruising windows up at 70 on the eway.
Old 06-16-2011, 06:32 PM
DavidGXP's Avatar
Saves a bunch of weight too!
Old 06-17-2011, 11:31 AM
Got any sound clips? I'm having to watch how far I go with the sound on this car since it really is the wifey's ride. I have one loud one, just want this one to have something a little extra. Swapping to a catless DP this weekend.
Old 06-17-2011, 04:30 PM
94ss06gxp's Avatar
if you love drone than thats a good setup for you. i had a magnaflow bullet w/ 4" case with 2.5" all the way back and the drone is sooo loud. but not gonna lie it sounded so sick. idk if the magnapack is the same one i had or not.
Old 06-17-2011, 04:34 PM
94ss06gxp's Avatar
If i were you i would just get the res deleted then throw 2 magnaflow muflers the 4"x9" oval ones at the back. Should be good for a daily driver. I have the 4"round and two 5"x8" and there is still some drone but sounds tame but very nice
Old 06-17-2011, 05:08 PM
Brian396's Avatar
I went catless DP with 3” magnaflows. I thought the drone was a little too much. But good god did it sound mean.
Quick Reply: removing baffles from exhaust tips
