Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Shifter slop question
Old 06-13-2011, 12:29 PM
jwilson2598's Avatar
Default Shifter slop question
So my new to me V had a UUC shifter installed by the previous owner @ Lindasy Cadillac about a year ago. However, it seems this thing has a ton of side to side play when in gear, and it actually smacks the console when I push it over to reverse. The repair order he gave me with it lists the shifter and bushings I think, is it possible they're shot again this quickly? Somehow this seems like too much play for a short throw shifter. Thanks for any help.
Old 06-13-2011, 12:42 PM
aurora40's Avatar
After putzing around with my shifter a crapload this weekend, I can say there isn't much you can guess about. Just open it up and look. Fortunately you can just look at it without removing much.
Pull the **** and boot off, get the foam out of the way, then remove the plastic plate that holds the shifter assembly up. Once that is out of the way, you can see the bushings, the shifter, and you can feel the linkage. See where the slack seems to be.
Old 06-13-2011, 01:06 PM
EdmundGTP's Avatar
The "more" linkage you have between the shifter and the transmission input rod, the more play you're gonna have..
That being said.. The linkage system of the V is... Rube Goldbergian to say the least...
Old 06-13-2011, 02:53 PM
Chris0nllyn's Avatar
I thought there was an screw on the linkage that you could tighten a little...
Old 06-13-2011, 02:54 PM
RADEoN's Avatar
there SHOULD be. There isn't.
Old 06-13-2011, 02:55 PM
Tell me this then, since this is my numero uno experience with these cars...does pushing it over so far for reverse that the shifter hits the console sound excessive? If it's normal, then so be it, but it seemed odd to me...
Old 06-13-2011, 02:58 PM
RADEoN's Avatar
with an aftermarket short shifter, absolutely not. I've said it before, and i'll say it again, i'm sure. The UUC shifter isn't that good.
Old 06-13-2011, 03:05 PM
RADEoN's Avatar
honestly, you ought to PM Brian (PISNUOFF on CF), and consider buying his shifter and bushings from him.
Old 06-13-2011, 03:18 PM
aurora40's Avatar
That sounds excessive to me
Old 06-13-2011, 08:45 PM
Thanks for the tips everyone...sounds like a console disassembly might be in my future.
Old 06-14-2011, 06:45 AM
aurora40's Avatar
You don't have to take apart the console, just the trim around the shifter that is attached to the boot and ****.
Old 06-14-2011, 04:06 PM
FuzzyLog1c's Avatar
Yep...get yourself a thin, flexible paint scraper, cover the tip with electrical tape (to avoid scratching the plastic), and follow the instructions on the FAQ.
Old 06-14-2011, 07:10 PM
aurora40's Avatar
I pulled the boot surround out by hand. Just grab it from the inside, the boot has plenty of give, and pull up the rear. Then it'll just come out. No need for a scraper.
