Rearend upgrade with turbo or spray?
Im thinking about putting a turbo or a nitrous kit on. I have the stock 10bolt but I'm not going to drag race it, just roll racing. Would I need to get a 9" or 12 bolt with say 600-800 hp or would the 10 bolt be okay.
I didn't know about the driveshaft being weak, okay I read where some people have said that easing the power in would help the 10 last but idk for how long. What rear would you recommend?
EDIT:is your car an m6 or a4?, a4 tend to be more forgiving on the rear, so you may get away with it for a bit longer.
yup the stock drive shaft is very weak, my drive shaft broke long before my 10 bolt. It broke dead center, just twisted in half. The drive shaft took out the transmission tail housing, y-pipe, and adjustable torque arm. This was at 485hp/440tq (old LS1, before the LS3) by the way. So i'd highly recommend a new drive shaft even if you don't upgrade the rear end.
It's a a4. Ive been reading that racing on the streets it's better to have a m6 so I might do a swap, but also picking the right stall and gears can be good, I just don't know what they are right now. 3600 stall w 3.73s?
LS1Tech Sponsor
If you want to order a rear with a differential that you'll never know is back there, but will also handle the power, I'd go with the Wavetrac. Here is a link to the Moser 9 inch with the Wavetrac. http://shop.brutespeed.com/Moser-9-I...h-Wavetrac.htm
http://shop.brutespeed.com/Brute-Spe...nformation.htm Info
http://shop.brutespeed.com/Moser-9-I...structions.htm Installation instructions.
Let me know if you have any questions. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Thanks Bob for that imformative reply. I think my age was playing a part on street racing, just occasionally. I don't have my computer with me, so this iPhone is a pain. Does the moser 9" w wavetrac bolt right in, I have abs w TCS. and how much would everything be that I would need including driveshaft?
Thanks
Felts
Thanks
Felts
LS1Tech Sponsor
Thanks
Felts
Thanks
Felts
$3515.00 shipped. Let me know if you have any questions. Thanks. Bob
__________________
LS1Tech Premium Sponsor
We have a few customers down south that this is all they do with their vehicle and many of them have our non braced housing with our billet clutch posi set up and been very happy with the results making decent hp through turbo set ups.
You are looking at our fabricated housing w/ drain plug brake line tabs and e-brake bracket, chrome-moly torque arm, trans cross member (long or short version), nodular iron case gears ratio of your choice using our rebuildable billet clutch posi, powder coated black, complete assembled set up for 4ch with your reluctor rings and brakes shipped to you for $3610 with a steel drive shaft using a good yoke.
It shows up to you and all you have to do is bolt it into the car and add fluid since it will come to you all complete, no need to worry about pressing on axle bearings, and bolting in the center section.
If you need any help with anything let me know and I will try my best to help you out.
