Putting a electric temp sensor in a 4l80e
Old 06-13-2011, 05:53 PM
Bobby G's Avatar
Default Putting a electric temp sensor in a 4l80e
Has anyone done this, where is the best spot to drill the hole in the pan?
Old 06-13-2011, 10:02 PM
gofastwclass's Avatar
Doesn't a 4L80E have a temp sensor built in it like a 4L60E? I can read the trans temp in a 4L60E via class 2 data with a proper scan tool.
Old 06-14-2011, 08:40 AM
Bobby G's Avatar
this is for a autometer carbon fiber temp guage
Old 06-14-2011, 09:43 PM
Mike52's Avatar
Which scan tool do you use to read this info?
Old 06-14-2011, 10:17 PM
sawzall wielding director
G-Body's Avatar
I haven`t done it on an 80e, but when I was looking for my 60e there were a couple schools of thought. Some said to put it in the pan (anywhere) so that it measures the temp of the fluid that the trans is sucking up. Others said that the true measurement is inline on the output line to the cooler B/C this is just after the converter and will show the peak fluid temp.
In the end I drilled the pan B/C I felt that it was the closest temp to the fluid that was passing through the friction material which is what I feel matters the most.
Old 06-14-2011, 11:34 PM
I have a few, but HP Tuners can read the trans temp among other things. My hand held scanners by Innova also read it in the live data stream.
Old 06-15-2011, 12:32 PM
Bobby G's Avatar
G- body do have a picture of where you drilled?
Old 06-15-2011, 01:26 PM
Chicago TDP's Avatar
on the drivers side of the trans, there should be some pipe plugs in the side of the case. They should be 1/8" NPT. On a truck trans a few years ago, I put the Autometer 1/8" NPT sensor in that port and it worked out perfect. The plug is an access port to read line pressure. It is right by the trans linkage area.....
Old 06-15-2011, 11:55 PM
G-Body's Avatar
I don`t seem to have a pic with it installed, and mine is a 60e not 80e. I just drilled a hole in the lower portion of the back of the pan toward the pass side and welded half of a pipe coupling in.
Attached Thumbnails Putting a electric temp sensor in a 4l80e-trans-temp.jpg
Old 06-16-2011, 12:51 AM
TurbopigB4C's Avatar
I always get leaks when trying to use a universal drain plug to mount a temp sender. I like to get the aftermarket pans with the temp sensor bung hole built in.
Quick Reply: Putting a electric temp sensor in a 4l80e
